Threads: 13
Thanks Received: 23 in 18 posts
Thanks Given: 31
Osram Nightbreaker Plus Gold Edition.
£14.99 pair, post free
Eurocarparts on line
Just bought mine 1800 hours ( H4 ) H7 also listed
The following 1 user says Thank You to jericlin for this post:1 user says Thank You to jericlin for this post
• taxi
Threads: 13
Thanks Given: 31
Well spotted, just shows how much some companies try to catch the unwary with their normally high prices, then cash in by massive cuts, whilst all the time getting cash flow with prices on the likes of Amazon.
Threads: 4
Thanks Received: 6 in 3 posts
I'm currently running Philips Blue Vision, do the Osrams give a better light? Need to buy some for the pug soon so if the osrams are better ill grab a couple of sets.
Threads: 15
Thanks Given: 46
5
While on the subject of headlamp bulbs, are all H4 bulbs the same fitting? Reason I ask is because theres not always a book in the shop to tell you specfic code number of bulb for specific car, ie Berlingo 3 headlamp bulb, so does any bulb marked H4 on the packet fit?
Threads: 32
Thanks Given: 18
Yes any h4 will fit.
Threads: 13
Thanks Given: 31
If you google - best headlight bulbs it comes up with reports from Which, Autoexpress, and questions on Pistonheads and no doubt more, only had time for a quick look. Haven't fitted mine yet so can't comment
Threads: 35
Thanks Received: 119 in 88 posts
Thanks Given: 3
4
05-09-2013, 11:50 PM
(This post was last modified: 05-09-2013, 11:52 PM by ntm1275.)
How many of these are needed for a 2010 mk3?
I've only just got the car and haven't had a chance to look what bulbs it uses
Does it use separate H4 bulbs for the dip and main beam meaning 4 are needed for both sides?
Threads: 52
Thanks Given: 87
5
Quote:Does it use separate H4 bulbs for the dip and main beam meaning 4 are needed for both sides?
No, it just needs two bulbs.
Threads: 28
Thanks Received: 13 in 13 posts
Thanks Given: 7
(04-09-2013, 05:45 PM)jericlin Wrote: Osram Nightbreaker Plus Gold Edition.
or £11.24 when u use the parts25 discount code.
MK1 Berlingo, Y-Reg 1.4 Petrol Now LPG Converted.
