A series of pictures that may assist people wanting to remove their carpet or just see the layout of stuff; not a gig for the amateur but nothing insanely hard either.
Photos will be added as reassembly continues in coming weeks.
[Image: 8oqz.jpg]
I'm preparing for carpet reinstallation here. The two 13mm headed bolts that earth to the underseat cross-rails have been removed, also the T20 which secures the handbrake switch is out and the switch itself removed. Wiring is also unclipped with a trim removal tool, from the centre tunnel just ahead of the handbrake.
This centre harness goes to the fuel pump and as such unless you're on a hoist it's easiest just to have lots of slack - rather than disconnect and pull forward into the cabin.
[Image: wp0i.jpg]
[Image: rcis.jpg]
[Image: gyt3.jpg]
The one immediately above, shows the mechanical adjustment for clutch pedal height - the rear 13mm head bolt is removed for ease of cable detachment. You wangle the pedal to get normal height then tighten the missing bolt plus the pivot shaft through bolt (mine was disturbingly loose).
[Image: 8oqz.jpg]
[Image: wp0i.jpg]
[Image: rcis.jpg]
[Image: gyt3.jpg]
