  • 1 Vote(s) - 3 Average
Sliding Door
Anyone else had any experience of problems with the sliding doors?
I'm having problems with the passenger door and it is grating a lot, the track is quite worn on this side, but I can't work out if it is that or not.
Hi, Try giving it a good dose of lube and see if it gets any better. Then you'll know it's that causing the noise.
Griff
Landmark
Ex 1.4 Berlingo Multispace
Apparently it seems, according to another thread somewhere, here that the coating/plating
of the track wears through and that causes the problem. If the track is badly worn then
also check the roller that runs in it. HTH
ServiceBox
Last Post: nonce
Yesterday 03:28 PM
Limp mode, no other symptoms.
Yesterday 11:37 AM
Adding aircon oil after component replacement
Yesterday 11:23 AM
Centre Air Vent On Dash
06-07-2025 10:50 AM
05-07-2025 11:41 AM
» Replies: 36
2.0 hdi clutch
05-07-2025 06:20 AM
Solenoide, Wastegate
05-07-2025 02:27 AM
All NS front head lamp bulbs blown?
05-07-2025 02:15 AM
Power steering Leak
Last Post: AugustinoHippo
01-07-2025 11:09 AM
install other safetywall
Last Post: mikeh79
01-07-2025 09:48 AM
