  • 6 Vote(s) - 2.5 Average
15'' Tyre sizes.. rubbing..
My 2002 berlingo came with xsara vtr alloys and new 195/65/15'' tyres fitted, they rub the inner plastic arch trim on mine (lowering didnt help).
i'm planning to fit some picasso 15'' steels this week, has anyone ran 185/55/15s at all and do they clear? Trying to avoid spacers really!
(09-09-2013, 08:41 PM)kens_soup Wrote:  My 2002 berlingo came with xsara vtr alloys and new 195/65/15'' tyres fitted, they rub the inner plastic arch trim on mine (lowering didnt help).
I have that exact tire size and my vans lowerd 120mm all round and I don't get any rubbing whatsoever Big Grin
Same rim width and ET?
If the OP is talking about rubbing on the rear (cue Ron) then it's probably a beam issue.
  • ron
Beam seems ok, stripped and reset the torsion bar and there was no play in the bearings, no idea on et!
You'll need spacers with 195/65/15. I run 185/65/15 without spacers they JUST clear the rear inner plastic arch.
I run 195/50/15 and no problems!
Rear light cluster removal
Last Post: phydaux
Yesterday 11:47 AM
Cranks but won't start
Last Post: MarkA67
Yesterday 10:45 AM
Last Post: BrianS
Yesterday 10:35 AM
ignition lock ggrrrrrrrrr
Last Post: Sikez2012
17-11-2025 10:07 PM
Engine Fan Running
17-11-2025 09:59 PM
Bettery Issues - A Solution.
17-11-2025 10:45 AM
Sound proofing windscreen
16-11-2025 02:43 PM
14-11-2025 07:34 AM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
