13-09-2013, 07:45 AM
(1.9D Multispace) I've just replaced the radio (wouldn't eject CDs) with a spare one I had lying around and managed to figure out which wires to swap so the radio kept the memory. However the clock display only displays the time at which you switch the engine on. If you press the button to set the time the the time updates to the current time but then sits at that time until you press the button again.
Obviously it's related to me swapping over the radio and presumably there must be another wire which should be connected to a live feed or swapped over. Can anyone point me in the right direction please.
Malc
Stupid computer!
Stupid computer!
alut:
