Threads: 2
Can anyone help me with by 2002 Hdi. Over the last two winters the car has not started well on cold days [/size][/font]and appears lumpy at tickover until it has run for a short while. All glowplugs are ok and the control box and temperature sensor have been replaced.
These made no difference so I rigged up a manual switch to activate the glow plugs, sadly it did not work.
I recall seeing a couple of posts that say a new starter motor is the cure ,is this true and has anyone else had similar problem and come up with a solution?
Threads: 50
Thanks Given: 743
A new starter motor will do nothing for a 'lumpy' tick over.
I would be looking at the condition of the battery. If its being hammered during start up then the voltage will drop until
the alternator has put back enough charge to restore the voltage at the battery terminals to around 14.5v.
If the battery tests OK then look at the battery lead connectors and earth leads. What voltage do you have at the battery terminals
directly after starting from cold with the engine running?
Threads: 2
Battery is new mate. I forgot to mention that she takes a fair bit of cranking and when it does start it seems as if it is not running on all four.I also get a good cloud of smoke.
Threads: 50
Thanks Given: 743
OK. I'd still be checking the battery voltage with a meter at the battery terminals
looking for at least 14 volts. If it's any less than you can suspect a poor connection somewhere.
Have you had a diagnostic check to see if there are any fault codes stored. If there are codes they will
greatly help in isolating any problem.
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
16-09-2013, 07:13 PM
(This post was last modified: 16-09-2013, 07:14 PM by brodfather11.)
Does it run OK after about ten mins. or so ? Once its het up a little?
Threads: 16
Thanks Received: 3 in 3 posts
Thanks Given: 2
Mine was taking longer to start and running a bit lumpy for the first few miles but after I swapped the fuel filter (after running far too low on fuel I think) it now starts like it used to and runs far better.
The job was simple BTW. 30mins for that and the air filter
Threads: 65
Thanks Received: 716 in 613 posts
Thanks Given: 227
50
I'd say the valve clearances need checking and probably resetting ( bet a pound they have closed up ).
Serieal Berlingo owner
