Threads: 16
Thanks Received: 1 in 1 posts
Thanks Given: 1
18-09-2013, 08:53 AM
Have encountered a problem with my mk1 berlingo van-when i start it, the wipers/indicators stop working, then, with the engine unning, they seem to reset, and come on after about 1 minute, with the engine running-when the engine is switched off, they work on ignition, untill the engine is re-started, then switch off, and seem to re-set after a minute or so, does anyone know whats causing this?
Apart from this, the vehicle seems to run fine! Am i right in thinking its bsi related?? Any help appreciated
Threads: 16
Thanks Given: 1
[quote='addo' pid='49770' dateline='1379495256']
I'd point my finger more at the underbonnet panel. Can you borrow a known good one to try?
hi, thanks for response, do you mean the under bonnet fusebox?
Threads: 67
Thanks Given: 1,045
Yes, as shown in several of the Fleabay items.
Threads: 29
Thanks Given: 67
20
If you switch your wipers off, start the van then switch them on what happens ? Our car does similar with the heater fan but it's not something that bothers me. I think it's something to do with the power management system.
