Threads: 20
Thanks Received: 3 in 3 posts
Thanks Given: 14
I've got horn issues, one minute it won't work the next it's fine. Could it be a bad connection in the steering wheel meaning the air bag has to come out & is it a simple job?
Threads: 27
Thanks Received: 15 in 14 posts
Thanks Given: 9
Likely just the horn is broke especially if you have drove thru any big puddles as the get filled with water very easily. All my years of driving i have yet to come across a horn that is faulty at the steering wheel.
Threads: 20
Thanks Given: 14
It's been like it for ages, apparently berlingos have a problem with the earth connection in the steering wheel
Threads: 27
Thanks Given: 9
Hmm possibility i have a newer berlingo and im a taxi driver and i've never heard of an earth problem with these, is it the mk2 you have?
Threads: 20
Thanks Given: 14
I'll give it a go I guess, must admit I'm slightly nervous about the airbag....
Thanks Given: 188
23
Make sure you dissconnect the battery and wait 30 minutes before trying to get the airbag off. There are a few threads on here about airbag removal.
Are we there yet?????
Threads: 29
Thanks Given: 67
20
If I don't press ours in just the right place it doesn't work every time. I am getting the hang of it now just experiment a bit while you are out of the way somewhere.
Threads: 20
Thanks Given: 14
Well took it all apart today & it is relatively easy, the bottom clip was a bit of a pig but got there in the end. Any all the connectors were solid so no problem there. Any had a new BSI fitted today & now it works fine as does everything else!!!
