  • 3 Vote(s) - 2.33 Average
Changing drivers door window
Has anyone had a go at this?
I have a 2002 blingo and got home yesterday to a nicely smashed drivers side window which I think was caused by some gardeners strimming.
I can get it done by Autoglass abd my insurance with a 100 quid excess, or I've found the glass itself for around 30 on eBay so could have a go myself (did one years ago on another car)
More hassle than it's worth?
(19-09-2013, 05:11 AM)kayak23 Wrote:  Has anyone had a go at this?
I think I would go to a scrap yard then you can look at how it comes out and work out how easy it would be to put in.If it seems too difficult then you don't have to buy it.I have done a couple in the past and its not rocket science just sometimes a bit tricky but you save money and don't have to declare a claim on your insurance.Good luck
One of the easiest cars to work on for stuff like this.
Door card off including speaker, winder handle and release pull, carefully slice away the glue sponge holding the insulating sheet on (the insulating panel is useful and about £40 to replace :eek: )
Remove the inside door mirror trim panel (Ron got all excited when I referred to it as a gusset panel). Remove the mirror.
Pull out the inner beltline rubber, then pull out the main rubber which is both beltline and glass run channel. Vacuum up the debris.
The window is speared in, front first and pointing down, then rotated once you're halfway down.
When fitting the replacement glass, ease the two glass holding clips in carefully.
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
