Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
What about Redex Diesel Additive, STP Additive or Forte additives. Been told its best to take car for a good run to lower the emissions prior to MOT tests, also.
Former 2011 Mk3 XTR owner
alut:
The following 1 user says Thank You to taxi for this post:1 user says Thank You to taxi for this post
• philip
Threads: 3
Thanks Received: 10 in 6 posts
Thanks Given: 1
19-09-2013, 04:18 PM
(This post was last modified: 19-09-2013, 04:33 PM by RegW.)
Its the deisel additive rather then the engine treatment
you want
Halfrauds also sell Millers
the usual wheeze is to bung a load in the tank and thrash it down the
motorway for a while.( drive it like you stole it sort of thing)
If you do a lot of town driving, the soot can really build up, so a jolly good
thrashing from time to time often helps burn it out.
Incidentally I've just ordered some Millers from Ebay
No idea if its snake oil or not but just playing the percentages
and throwing a tenner at the old thing.
Some folk swear by it and as I usually get supermarket fuel and
dont use the van a lot and when I do its usually local runs, It seemed worth
a try.
C15 interloper (I just snuck in one day)
The following 1 user says Thank You to RegW for this post:1 user says Thank You to RegW for this post
• philip
Threads: 67
Thanks Given: 237
50
Yes put the juice in the tank but a good ploy advised me by my MOT man is to remove the fuel filter take out half of the fuel and replace with diesel cleaner. ( shortly before the test )
Restart the engine and just let it idle for 5 mins - NO revving
Also well worth doing a long fast run before the test, diesels like the open road and always run better after a good clear out.
There are indeed lots of varieties of snake oil out there but injector cleaner is one of the exceptions.
Serieal Berlingo owner
• philip
Threads: 50
Thanks Given: 743
19-09-2013, 10:15 PM
(This post was last modified: 20-09-2013, 01:19 PM by Ol'Jeffers.)
I always use Millers. It does decrease fuel consumption and improves the smooth running of the engine irrespective
of which fuel that I use. ( So there! )
Threads: 20
Thanks Given: 2,126
18
I have heard that the occasional top up with the super duper diesel does good.I haven't tried it as I find an extra 10p per litre reduces me to a tearful,shivering wreck.:thumbsup::whistle:
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• geoff
