Threads: 16
Thanks Received: 1 in 1 posts
Thanks Given: 14
Hi All
Just purchased my first Berlingo Van 55 plate. Bought it at the weekend and just realised the oil reservoir is cracked and leaking. Nothing major but obviously will need to fix it and was thinking of doing it myself. I'm an engineer but don't have much experience with vehicles. Can't really find any videos online but i'm told its relatively simple.
Drain the oil, take the reservoir off, replace the gasket and put on the new reservoir.
Sounds easy enough but would you advise and if so any idea where is a good place to order parts from??
Thanks in advance
Threads: 13
Thanks Received: 13 in 10 posts
What reservoir are you referring to, is it the power steering fluid/ brake fluid or engine sump thats cracked n leaking?
The following 1 user says Thank You to Barkas for this post:1 user says Thank You to Barkas for this post
• RolyG
Threads: 51
Thanks Given: 23
When I did the last service on mine (DW8) I noticed that the sump was quite rusty in one corner. I cleaned it up and painted it with Rust Eater but it is a concern.
Malc
Stupid computer!
Threads: 16
Thanks Given: 14
I think I will go for it and fix it myself. The next issue is what sump do I go for. I have started looking online and there seems to be quite a lot of variants. How do I make sure I order the right part?? And is it advisable to replace the gasket and filter while I have it stripped down?
Threads: 50
Thanks Given: 743
You will need to replace the sump gasket. Oil's expensive enough with out letting it escape!
Threads: 67
Thanks Given: 1,045
A good number of members here are signed into Service Citroën; this allows access to part numbers and UK retail pricing on genuine bits. To evaluate the part you require, would mean providing the last eight characters of your VIN.
Threads: 16
Thanks Given: 14
Thanks All. Managed it no problem. Got a part from a breaker so hopefully it will be okay! Job No.1 complete!
