  • 2 Vote(s) - 2 Average
[Engine] Engine header tank gt water in
Hi I'm new to this site so can some one help plz I brought a berlingo 1.6 enterprise last Sunday it seemed to be running ok till I got lack of power and a whirls ting noise 4 days a go so pulled over to find oil in the header tank wat is this problem the old owner had head gasket done 3 mouths ago
As a mechanic, I always steer well clear of purchasing cars trucks vans or motorbikes that show sign of....or have owners declaring..." its just had the head gasket done recently mate"!!!....this tells me straight away that the engine has more than likely been overheated as this is usually the symptom that has grabbed the drivers attention to the head gasket failure in the first place, a failed head gasket can cause an overheating engine, on the other hand a overheating engine can cause the head gasket to fail, and once the engine has been overheated it has been damaged to a unknown extent and often as far as complete destruction, the owner, realising this, then has the gasket replaced, and swiftly sells the car on, the new owner then runs into continuous problems with the engine....loss of power....strange noises.....poor starting...water in the oil...oil in the water...and snapping timing belts due to a partially seized overhead camshaft which is usually the first mojor victim on a modern overheated engine. To initially assess the limit of damage, take the car to a garage and have the water system pressure tested, the mechanic will listen for the noise you have, and will fit a pump to the header tank and increase the cooling system pressure to a certain limit as recommended by the manufacturer, this will show up any weaknesses such as internal cracks. Good luck .
Ok thanks we'll we don t no no think about cars but seemed ok different garages are sayin different thinks like head needs doing again along with a oil cooler I don t no if it's true
Could be just the oil cooler that's kaput.
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
