26-09-2013, 08:58 PM
Hello,
I am going to change te coolant from my mk2 1.6 Hdi 90hp van.
I have a Haynes manual and it says to first let the coolant drain from the radiator and second to drain the rest out of the engine by unbolting the cylinder block drain plug.
Haynes says it is located at the rear of the cylinder block but no picture at all...
Where can i find that drain plug ? And as far is i can see there is only 1 bleed screw in the heater outlet hose at the bulckhead, is that correct?
I hope my english is understandable beeing a dutch guy..
Thanks in advance.
Thanks in advance.
