  • 6 Vote(s) - 2.67 Average
brake problems
Had a problem with the master cylinder which has now been replaced.Bled several times now and still not working as they should,can still feel air in the system as I press the pedal. Does anyone have any ideas?
Get it bled with a pressure bleeder , that's really the only way to bleed them.
Make sure the load limiter valve is open for bleeding the rears.
Yes! Try searching on this site for "Bleeding brakes" or similar.
There are several different models of Berlingo and you haven't told us which you have.
There's a special procedure, for instance, if you have ABS and many bleeding problems
have been experienced with the bleeding of the rear drums on Mk.2 models.
To give you a start try this link:
http://www.berlingoforum.co.uk/showthrea...ing+brakes
Make sure the valve near the osr wheel is not seized. You wont be able to bleed the brakes if it is.
[-] The following 1 user says Thank You to DAVIDI1 for this post:
  • RolyG
Next gen Berlingo coming 2030
Last Post: shedpete
Today 08:36 AM
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
