  • 2 Vote(s) - 2.5 Average
clutch problem
morning all, im a new boy, with a 52 plate multispace 1.9 d, can someone suggest please where to adjust the clutch cable as last night i couldnt select certain gears, no crunch or loss of pedal so believe/hope its a matter of adjustment:
brickwall:
[-] The following 1 user says Thank You to daren for this post:
  • Ol'Jeffers
My car is 2000 - not that much older - and has adjustment on the side of the pedal box.
There's a shaft with bolt/nut the pedal pivots on, and further towards the motor another 13mm headed bolt. You slacken both and adjust the pedal position. lock it with the furthest bolt and then tighten the pivot shaft bolt again.
That said, it may be the release bearing is wearing through your release fingers, or the fork bushes have called time.
yes indeed, thanks just had a look and the long fork bush had literally come off, so i couldnt select reverse and fifth gear, ive taped it together and now works, new one needed, cheers
Hello Daren welcome to the forum
Diagbox 7.57 download
Yesterday 09:13 PM
Yesterday 05:26 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
