  • 4 Vote(s) - 2 Average
front suspension knock
Knocking noise from offside front suspension - replaced drop links so not them. I can feel movement if I rock the wheel at 12 o'clock, with car on the ground. I think I can feel the movement if I put my hand on the top mount while I'm rocking it with the other so it all points to the top mount worn. Anyone else had similar? Is it a straightforward job? I'm thinking it would make sense to do the shocks at the same time.
2002 mk1 multispace 2.0hdi
[-] The following 1 user says Thank You to dwlawson for this post:
  • Ol'Jeffers
Welcome!!
Are you sure the bottom ball joint is ok. Had the same as you on mine.
Griff
Landmark
Ex 1.4 Berlingo Multispace
thanks Griff. Bought two Lemforder wishbones from mister-auto. Looks a reasonably straightforward job. Haynes use a big lever to pop the balljoint out whereas I would have been tempted to reach for the hammer.
Anything to watch out for? Is there a risk the driveshaft pops out while I'm doing this?
Dave
when i replaced my lower arms the drivers side was easy but the nearsides a bit more fiddly,like you said watch for the driveshaft popping out and puking gearbox oil over your drive!
I have to admit to resorting to a ball joint splitter to get my n/s one off (2002 1.4 has seperate ball joints)
Griff
Landmark
Well I replaced the wishbones and no improvement so I decided to replace the top mounts. Bought new shocks as well as it seemed daft to put the old ones back on. Just as well I did as it was the offside shock that was knocking.
[-] The following 3 users say Thank You to dwlawson for this post:
  • CandR, RolyG, taxi
Glad you got it sorted.
Griff
Landmark
Just a heads up that I had a similar problem and it turned out to be the drop-links that were worn. Easy enough to remove and check.
[-] The following 1 user says Thank You to davehills for this post:
  • RolyG
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
