  • 6 Vote(s) - 2.5 Average
Lack of vacuum to turbo 1.6 HDI
Hi, been having trouble with turbo boost. I have checked the turbo itself and that seems fine. Also put a vacuum pump on the actuator and that seems fine. Then tried the vacuum pump on the pipe going to the actuator with the engine off, applied vacuum.....nothing. Started the engine with the pump still attached.... And still nothing. Pumped up vacuum and it disappeared straight away. Is this a leaking vacuum pipe or is the're a solenoid or a regulator anywhere that I don't know about. Thanks in advance.
Difficult to grasp where you are testing the pipe, as they vary according to Turbo type .
Basically there is a vacuum solenoid at the back of the engine above the longest driveshaft, it is usually brown in colour.
(01-10-2013, 07:31 AM)Lighty Wrote:  Difficult to grasp where you are testing the pipe, as they vary according to Turbo type .
SOLVED!!! Exactly that mate. Got a vacuum control solenoid from the scrappy for a tenner and the van drives like new. Brilliant.
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
