Thanks Given: 1
Hi all,
thinking of getting a second-hand Berlingo, and wondering which is the most economical model to run as I'll be doing a lot of miles in it. The "official" fuel economy figures make the 1.6HDi look much better than the 2.0HDi and 1.9D. Is there really that much difference?
Threads: 15
Thanks Given: 46
5
30-09-2013, 07:00 PM
(This post was last modified: 30-09-2013, 07:02 PM by Opensauce.)
My previous 1.9D Berlingo did about 42mpg on a 70mph motoway trip although it did struggle to cruise at 70, a bit of a hill & it slowed down. My 1.6hdi current model Berl does about 48mpg on a 70mph trip albeit on fairly flat roads but does maintain speed uphill. The 1.6 is a more modern & economical engine but if you do go for one ensure you have a main dealer service history as oil change interval with correct grade oil used is critical on these engines.
Threads: 28
Thanks Received: 33 in 23 posts
Thanks Given: 45
Mine is only doing 44-45 mpg and I drive it like miss daisy. Its a shame really as i was expecting more than what I get. 1.6Hdi too. Been very reliable though.
Threads: 19
Thanks Received: 55 in 38 posts
Thanks Given: 19
My 2005 2.0 HDi (DW10 engine) gives just short of 50 mpg at 60mph but drops quite quickly when faster. At 70mph it returns about 44 mpg. No doubt a factor is its decidedly unaerodynamic shape.
Threads: 50
Thanks Given: 743
The 1.6 TDi Mk.3, logically, is not going to give quite the same economy as the earlier and smaller Mk.2
with the same engine.
On a long run, and I've now done several over 300 miles, I usually get around 58-64 mpg The ECU has been re-
programmed for more torque and I can drive at 30mph in 5th. Also I always use Millers Diesel Additive
on every fuel stop. I do wish, however that the newer dual-scroll turbo-charger on the 115bhp
Mk.3 would fit on the older Mk.2....
The following 1 user says Thank You to Ol'Jeffers for this post:1 user says Thank You to Ol'Jeffers for this post
• addo
Threads: 38
Thanks Received: 31 in 27 posts
Thanks Given: 69
01-10-2013, 03:37 PM
(This post was last modified: 01-10-2013, 03:38 PM by chronyx.)
Speed is everything in the 1.9D.
I got more MPG while towing a 220KG motorbike and bike trailer (let's say 100KG) and loaded with tools/clothes for a weekend rallying.
Stayed at 55 - 65, behind lorries and made it to Northumberland (420 miles) with diesel left over.
70+ mph with just the van and normal work tools and materials (Around 150kg) will see a tank last 390 - 400 miles.
It also has a roof rack but no roof box.
2004 1.9D Multispace/Budget crew cab work van!
