Threads: 67
Thanks Given: 1,045
You're still clear of the indicator bars. Interesting to see, is the tyre specs in your first photo; tread wear 240. This is quite a soft compound.
Threads: 39
Thanks Given: 1
4
Our Berlingo is just coming up to 25000 miles, it has just been serviced and there is 3mm of tread left on each tyre. The garage recommend changing before winter (I have checked the tyre safety websites and stopping distance on tyres this worn are alarming). It is going for MOT next week and they are fitting 4 new tyres but not Michelin. The garage has matched the price that I can buy them for and get them fitted using the Internet.
Peter
Threads: 32
Thanks Given: 18
There looks plenty on those. I don't use the wear indicators as I believe 1.6mm is a very dangerous tyre in the wet. I change mine at about 3mm.
Threads: 20
Thanks Given: 2,126
18
I agree with Steve,1.6mm is not enough in the wet,but I keep them 'till 2&a bit, driving to allow for wet etc.:thumbsup:
Strawberry flavoured windows
Threads: 16
Thanks Given: 46
5
Its usual to change tyres tyres when they reach 3mm tread depth. The op can buy a tread depth measuring gauge from Halfords etc. I got just over 30k miles from my original set of Primacys by rotating all 5 around. I'm 15k into my second set of tyres, much cheaper Avons which are wearing equally as well as the Michelins. I rotate the spare across back every 2mnths then change front to backs halfway through tyre life. Leaving it permantly in the carrier will damage sidewalls eventually in my experience.
Threads: 50
Thanks Given: 743
i've had very good results from Falken ZE914 tyres. Good balance of mileage and value and the performance is good.
The following 1 user says Thank You to Ol'Jeffers for this post:1 user says Thank You to Ol'Jeffers for this post
• addo
Threads: 67
Thanks Given: 1,045
ZE912 fan here. Never mind the wear rate, a nice sticky all weather tyre.
Threads: 50
Thanks Given: 743
912s superceded by 914s, Ad!!
Threads: 67
Thanks Given: 1,045
Different factories, I'd say. They're still flogging the 912 here with no mention of a successor. Ours are Korean or Chinese made. Yours may well be Japanese.
