Threads: 67
Thanks Given: 1,045
Not in my handbook, RPO 8500 (pre-mux).
Behind the front roof light is a white two pin plug with heavy gauge feed wires. Thicker than the cigarette lighter feed. Has anyone an idea what it may be intended for?
I'm tempted to free it from the roof and plumb down for an aux power socket in the console.
Threads: 50
Thanks Given: 743
That's exactly what it's for! Remember the old canvas full length sunroof on the Mk.1?
I wouldn't mind betting it would use that supply when it was fitted. I've never seen a Mk.2 with
an electric roof but Citroen may have left it in just in case they made one available or, more
likely, the early Mk.2 used the same harness as the late Mk.1.
Threads: 38
Thanks Received: 31 in 27 posts
Thanks Given: 69
How many amps is it?
2004 1.9D Multispace/Budget crew cab work van!
Threads: 67
Thanks Given: 1,045
Not sure; haven't identified its feed yet. I'd feel comfortable drawing 30A through it. Mine looks pretty much the same as Pieface's photo.
The sunroof idea has one question mark: how do you reverse the motor?
• chronyx
Threads: 38
Thanks Given: 69
Reverse polarity on a DC motor
Threads: 67
Thanks Given: 1,045
03-10-2013, 06:24 PM
(This post was last modified: 03-10-2013, 07:06 PM by addo.)
One side of the plug is hard earthed, though.
- Or was the sunroof switch in the roof just there? I'd have assumed it was like other PSA sunroof switches and had a plug like the power window feeds.
Threads: 67
Thanks Given: 1,045
I've got an idea... What if it was the power feed for the Modutop auxiliary roof blower?
Rustscrat, does this circuit have a connector "BA 2V"?
Threads: 50
Thanks Given: 743
Isn't your car prior to 'Modutop' Ad? Did M49 have Modutop?
The following 1 user says Thank You to Ol'Jeffers for this post:1 user says Thank You to Ol'Jeffers for this post
• addo
