  • 4 Vote(s) - 3 Average
Removing rear seats
Hi, Good to find this forum, have just picked up a 2010 Berlingo Multispace for moving the dogs around, it is the XTR model.
And so to my first question, How the hell do you remove the rear seats? I assume they can be removed? at least in the current brochure they show a photo with 1 seat removed, but I´m buggered i I can work out how to get them out.
Thanks for any pointers
[-] The following 1 user says Thank You to Sparks1061 for this post:
  • Ol'Jeffers
(05-10-2013, 01:15 PM)Sparks1061 Wrote:  Hi, Good to find this forum, have just picked up a 2010 Berlingo Multispace for moving the dogs around, it is the XTR model.
Hi Sparks
Welcome to the forum.
If you haven't got an owners handbook you can download one here:
http://www.ukandeuropetravel.com/images/...ndbook.pdf
Basically, you fold them flat, then reach behind them and lift them forward using the release bar and lift them out vertically. (Probably better explained in the handbook.)
Hope this helps.
Mark
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
[-] The following 1 user says Thank You to MarkT for this post:
  • Sparks1061
Hi Sparks
Hope this helps.
Mark
Thanks for that, I will give it a try tomorrow, would never have worked it out on my own Smile
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
