  • 11 Vote(s) - 3.18 Average
Berlingo horn
Im far from good at electrics but here goes.
Horn wasn't working at all, disconnected it and wired it from battery and it works fine.
Connected it back again and used a bulb tester connecting the earth clip to the battery neg and the other clip to the horn terminal, when I push the centre of the steering wheel the bulb lights.
Took the clip off the horn terminal and put it on the other horn terminal and the bulb lights when the horn is pushed again.:brickwall:
Am I right in assuming that the horn push is ok and the horn is fine so can it be an earth fault?
Any guidance greatly appreciated
the usual fault when no horn is the earth , some have earthed the steering column and it seems to work then.
There are a lot of posts about it and how to cure the fault.
Try earthing the steering column and try again. Quite a few members have found this works.:thumbsup:
Thanks guys. Horn now working Big Grin
[-] The following 1 user says Thank You to ytre for this post:
  • Ol'Jeffers
My Berlingo Multispaces
Yesterday 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
