Threads: 24
Thanks Received: 52 in 44 posts
Thanks Given: 9
Andre,
have noticed adverts within the threads now. Is this required to keep the forum going? How are you doing with server space etc?
Threads: 50
Thanks Received: 475 in 420 posts
Thanks Given: 743
I think you'll find that if you make a modest contribution those ads disappear....I don't get them! :-))
The following 1 user says Thank You to Ol'Jeffers for this post:1 user says Thank You to Ol'Jeffers for this post
• addo
Threads: 147
Thanks Given: 263
11
There should only be an ad at the top, at the bottom, and every 4 or so posts (ads dont appear inside posts, but between posts and are quite small).
They have been there for a few months now - necessary evil i guess is the way to put it.
The following 1 user says Thank You to Andre for this post:1 user says Thank You to Andre for this post
• addo
Threads: 13
Thanks Received: 44 in 29 posts
Thanks Given: 29
One easy solution is to use the Firefox browser with the Addblock Plus plugin installed. Works a treat.
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
Threads: 32
Thanks Given: 18
I don't mind the ads if they pay for the forum.
If you block them you are taking away money from the forum that you use for free!
Threads: 24
Thanks Given: 9
They don't bother me, and I would never click on them. It's just there was one that said "your PC needs a tune up" or such like. Clearly this is a standard ad and in no way has the perfomance of my PC, or phone in this case been measured etc.
Can these ads be trusted, with so many scams about these days?
The following 1 user says Thank You to Modmytop for this post:1 user says Thank You to Modmytop for this post
• RolyG
Threads: 23
Thanks Given: 46
5
The PC 'tune up' Adverts should be avoided at all costs. All they will do is tell you just how poor your PC is performing (when all is fine) and suggest you spend ££££'s on some software that does no good at all. Possibly giving you a Trojan or virus along with it!
