07-10-2013, 07:16 PM
So, the MOT is due on my mk1 Berlingo 2.0hdi next week, but, I have a bit of a problem. And by 'bit' I mean pretty massive possibly.
I have the non-functiong dashboard problem that seems to affect a good few people, so was wondering what the legality is with regards the dashboard/speedo. I have a fix in place, it is a device connected to my obd port that shows my speed/rpm/engine load/intake temp/coolant temp all at once, and as this would be more accurate than a needle on an analogue instrument I was wondering if this will pass an MOT?
I have seen that as long as the dashboard isn't clearly broken or that the speedo is slow to react to speed changes then it is a fail. But hoping someone else with a bit more knowledge can advise me, as frankly, I can't afford to put the van in for the MOT if it will fail badly, as there a few little other niggles too (slight knock on right rear, dipped left light pointing downwards etc etc).
Cheers for any help.
