Threads: 23
Thanks Received: 24 in 15 posts
Thanks Given: 11
Having owned 2 berlingo's since 2000 (loved the car) the 1st 1.9D was having serious BSI problems when the aux belt let go and caused the timing belt to slip (101,000).
2nd 2.0Hdi all reasonably fine until 3 months ago when I started getting spurious warnings like Temp, brake fluid level, or just plain stop, and then the speedo started wandering causing erratic pull away etc none of this lit up the engine light so no codes logged,
I have seen berlingos with space shuttle mileage's. Have I had friday specials? Anyway it is now sold and I will not be dealing with elderly french electrics any more.
Just want to thank everyone on here for helping out with my questions etc.
And its gooodbye from me
Threads: 32
Thanks Given: 18
Sad to see you go buddy. My 2002 hdi van is showing 141k but the speedo has been barely working for around three years so the mileage is probably 160k plus. I've had it almost seven years and it's been relatively trouble free. Just had to change the rear brake shoes, first time I've done so, the van had 57k on the clock when I got it so they were probably the originals.
What will you replace it with?
Threads: 67
Thanks Given: 1,045
Surely Husqyman won't be able to stay away from the sparkling wit and throbbing double entendres...
I'm just shy of 250000 miles (400K kilometres), original 1.4 motor/box, one head service only, new matrix recently and the plastic heater hose coupling died from old age last week. Driver's seat replaced. A/C features original receiver drier and blows cold. Minor wiring niggles to the left rear light cluster only.
Threads: 32
Thanks Given: 18
11-10-2013, 12:38 PM
(This post was last modified: 11-10-2013, 12:39 PM by steve valentine.)
(11-10-2013, 12:11 PM)Husqyman Wrote: I could put up with the speedo not working but it made it v difficult in town and the beep when it was wandering up & down at standstill was bloody annoying to.
(11-10-2013, 08:19 AM)addo Wrote: Surely Husqyman won't be able to stay away from the sparkling wit and throbbing double entendres...
You havn't got rid of me completly I am going to skick around for the "shining wit" (think thats the right way round:whistle
And i may be able to help somone else even if it's just "they all do that sir"
It beeps because with the speedo going up and down it thinks you're moving with the handbrake on. I removed the switch from the handbrake, two minute job, no more beeping :thumbsup:
Threads: 67
Thanks Given: 1,045
I would LOVE a "handbrake on" beeper for my Pug 605.
The number of times I've thought "She seems a bit sluggish" and then realised I've been tooling along at 40 with the handbrake applied for thirty seconds or more...
And yes, the Rev. Spooner's shining wit... He once introduced renowned American banjoist (and erstwhile preacher) Eddie Peabody to an audience thus: "Mr Playbody will now pee for you"...
