Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Not 100% sure but if you fill the tank with diesel it should be ok?!
I DO MISS MY BERLINGO
Threads: 16
Thanks Received: 30 in 25 posts
Thanks Given: 2
I've done about the same in a X reg MK2 Renault Scenic engine & just brimmed it with diesel with no ill affects. I've done far worse with a 53 reg 2.0 Rover 75 (BMW) diesel where I put 3/4 tank petrol in a virtually empty tank. It didn't like it but I drove the 1 mile back to the garage & brimmed it with diesel & kept doing so every 50-100 miles or so with no noticable effects.
I'd think for that small amount you'll be fine if you make sure you top it up with diesel.. All the advice I had - AA first time & my mechanic the 2nd was that modern diesels are quite robust in this regard & wil even benefit from the decoke that will result! I didn't think I'd get away with the Rover as I'd put so much in & set off but my mechanic was right & the car continued to give faultless service for the rest of my time with it.
2015 Cactus Feel BlueHDi
2014 Dispatch Van LWB
Ex 2013 Berlingo XTR 1.6HDi 115 owner
Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
14-10-2013, 07:20 AM
(This post was last modified: 14-10-2013, 07:23 AM by taxi.)
Just keep filling it with Diesel for next couple of days to dilute it as much as possible.
Former 2011 Mk3 XTR owner
alut:
Thanks Given: 188
23
If it was me I would fill it to the brim with derv and drive it then every 100 miles top it up and dilute the mix down.
Are we there yet?????
Threads: 67
Thanks Given: 1,045
How about tipping in a bottle of two-stroke oil?
The following 2 users say Thank You to addo for this post:2 users say Thank You to addo for this post
• RolyG, ron
Threads: 19
Thanks Received: 55 in 38 posts
Thanks Given: 19
I put 6 litres of petrol in mine before I noticed. I then filled it with diesel and drove about 120 miles with no ill effects. The only effect I did notice was that fuel consumption appeared to be worse. No bangs, no smoke, no after effects. Suggest you keep topping up with diesel as others suggest, don't drive it too hard, and stop worrying.
Threads: 12
Thanks Received: 4 in 3 posts
Thanks Given: 4
Well you lot..a big thanks may be in-order to you..not for sorting my problem out, more-so for putting my mind at ease..I will indeed fill it to the brim 2mrw & as mikeB says..'stop worrying'
Cheers now, best ones as ever to you all U.S.
Threads: 35
Thanks Received: 119 in 88 posts
Thanks Given: 3
4
I know the question was about a Mk1, but would the advice be the same for a Mk3 1.6 HDi engine with a particle filter?
I haven't put petrol in mine as yet, just wondering if it would cause damage to the newer engine
