Threads: 2
Thanks Received: 1 in 1 posts
I have a 62 plate Berlingo van 1.6 75 enterprise
I travel from perth to glasgow every day for work.
(60 miles down 60 miles up)
I fill up £70 on monday and it lasts until wed/thurs so just shy of 400 miles on a tank.
Is that correct or is it F****d again?!
(already had a new clutch and mass air flow meter.)
The following 1 user says Thank You to mcdade1 for this post:1 user says Thank You to mcdade1 for this post
• Ol'Jeffers
Threads: 67
Thanks Given: 1,045
Are you carrying much weight, or driving fast?
Threads: 52
Thanks Given: 87
5
So what does the display say your average mpg (or l/100km) is??
Threads: 6
Thanks Received: 5 in 4 posts
Thanks Given: 11
The figures he quotes work out at about 40mpg, based on diesel being at £1.40 a litre. That is similar figures to what I get when fully laden, or empty if my right foot gets a bit heavy.
Threads: 2
I sit at around 65/70 mph. Van is always empty.
MPG on screen is around 40 mpg, i thought/hoped it would have been more as it is only a 1.6 and couldnt pull me out of bed.
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
At a constant 70mph my Berlingo used to do around 42mpg so its not that far out. Remember its shaped like a brick!
I DO MISS MY BERLINGO
Threads: 50
Thanks Given: 743
I'd get it tuned by someone like Quantum. They can increase the low end torque significantly
and give you a better performance curve. Mine will comfortably sit at 30 mph in top.
On a run greater than 100 miles, cruising at 60-65 mph I see high 50s/low60s mpg.
Mine is a Mk.2....92bhp 1.6HDi
Thanks Given: 188
23
Just a thought but what revs are you changing up at?
Are we there yet?????
Threads: 35
Thanks Received: 119 in 88 posts
Thanks Given: 3
4
I do a lot of journeys of 40mph and under and my 110hp XTR averages at about 49mpg
On a long run it does up to 55mpg, just as long as there aren't too many hills
I used to do a lot of motorway miles (at 70mph+) Consumption was down around 40mpg.
I now infrequently do motorway trips and find cruising around 60 on A roads gives 50mpg+.
Hilly, windy country roads aren't too great either.
