  • 6 Vote(s) - 2.83 Average
lower suspension wishbone
hi, can you help. is it possible to fit the lower front suspension arm bushes, without fitting a complete new arm. its not the ball joint type.its 97 1.8d van.... thanx
(14-10-2013, 01:50 PM)billyf Wrote:  hi, can you help. is it possible to fit the lower front suspension arm bushes, without fitting a complete new arm. its not the ball joint type.its 97 1.8d van.... thanx
I did on mine, but for the price and hastle, I'd buy the complete unit. :thumbsup:
  • ron
cheers, i can see your point. but budget is very tight.
If it's the "P" shaped bush then I think I had to grind mine off as the inner sleeve was rusted on, then the new one was pressed on but again it was a tight fit. Confusedalut:
thanx. yea its the p shaped bush. now i just discovered u have to take the whole arm off. to replace the bush. should be fun. lol.
do i need new nuts. as i understand they are coated with some locking agent.
appreciate the info bud. thank you
As long as there tight should be enough. don't forget to measure the distance the old bush is on the stalk and also the direction of the "P".
Good luck. Confusedalut:
cheers. dually noted. Big Grin
Rattling calipers
Last Post: Chrisfox1975
Today 08:09 AM
eolys
Last Post: magoo1
Yesterday 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
