  • 7 Vote(s) - 3.86 Average
Dual mass flywheel or not?
Hi I've got a Citroen Berlingo 1.6 HDI van 58 plate.I need a clutch but Partco are saying that its got a Dual Mass Flywheel but Citroen Main Dealers say that it does not so who is right? Thanks in advance.
34 views someone must know??
Obviously not, or they'd have answered.
Patience :thumbsup:
citroen main dealers should get it right .
2010 1.6 hdi 110bhp XTR
(15-10-2013, 06:21 PM)rdfb2 Wrote:  citroen main dealers should get it right .
Don't count on it!!
However given the right info. a good indie Cit/Pug repairer will be able to help you with this.
Possibly both are available, solid in vans & dmf in cars maybe? The Citroen dealer parts screen should show both in that case. Is the clutch slipping, ie worn clutch plate or have you suddenly lost drive completely, ie dmf failure? If dmf has failed it is normal to replace clutch at same time but if you have a solid flywheel then presumably all you need is a replacement clutch? Whatever the case, in some cars it is possible to fit solid flywheel in place of failed dmf, I think.
CONFIRMED Berlingo vans do not have Dual Mass Flywheels.
[-] The following 3 users say Thank You to raptornexus for this post:
  • adam3rdcanvey, Justbeenrsed, Opensauce
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
