excssivaly smoke on start up and when idle
Threads: 2
Thanks Received: 2 in 1 posts
Thanks Given: 1
has anyone any idea what this could be iam a mechanic but this is giving me a headache it wont even pass a mot like the way it is,always been service as it should be,i was thinking a long the line of egr intake manifold full of shite
if so can i blank the egr off with out any engine lights coming on
thanks karl
its a 1.6 hdi 85000miles mpv
Threads: 67
Thanks Given: 1,045
Is the turbo OK - oil seals? 1.6s are the infamous one for turbo problems.
Threads: 2
Thanks Given: 1
i checked the turbo was no play etc but on autodata apparently their should be a seal to stop oil run back down the turbo pipe !!
the smoke is a dense black not blue/white like oil burning
Threads: 67
Thanks Given: 1,045
Have you seen all the amateurs talking about using stuff like oven cleaner to de-crud the turbo vanes and EGR circuit? Maybe it's worth a crack to in your situation.
Threads: 50
Thanks Received: 475 in 420 posts
Thanks Given: 743
You can try blanking off the EGR as blanking off plates are cheap on eBay.
AFAIK this will not cause any errors to display.
Threads: 2
Thanks Given: 1
cheers going back today given it a good once over
also how do you fill the BIG fuel filter after replacing
Threads: 9
Thanks Received: 6 in 6 posts
(16-10-2013, 11:53 AM)karl mcghee Wrote: has anyone any idea what this could be iam a mechanic but this is giving me a headache it wont even pass a mot like the way it is,always been service as it should be,i was thinking a long the line of egr intake manifold full of shite
thanks karl
its a 1.6 hdi 85000miles mpv I had excessive smoke on start up and would stop after about a min depending on the weather.
For me it turned out to be a simple glow plugs which tested ok but when i decided to change them 3 came out fine but 1 must had never been changed as was a bugger to get out and looked nackered, changed them and never had smoke since on start up, be careful not to bugger the thread on the engine.
I did clean the MAF previous to no effect.
Im not a mechanic i just got the information and did it myself, hope this helps.
Threads: 2
Thanks Given: 1
(19-10-2013, 04:50 AM)mitumatu Wrote: (16-10-2013, 11:53 AM)karl mcghee Wrote: has anyone any idea what this could be iam a mechanic but this is giving me a headache it wont even pass a mot like the way it is,always been service as it should be,i was thinking a long the line of egr intake manifold full of shite
thanks karl
funny you said that as am getting a glow plug code P1351
serviced it today and it doesn't smoke that much if at all now but he had been out in it before i got their,also had maf sensor code but clean it and cleared code and it aint come back but the glow plug code still remains
Threads: 9
thanks karl
Im not a mechanic i just got the information and did it myself, hope this helps. Check in morning first start as mine would smoke for a while in morning until engine was warmed up then it disappeared, was really embarrassing, smoke would travel down my street :whistle:
M59 1.4 Petrol question
Yesterday 08:47 AM
Yesterday 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
15-03-2025 04:34 PM
