  • 3 Vote(s) - 3.67 Average
[Transmission] Front Differential
1998 Berlingo Panel van 1.8 D 600
Front Differential is noisy. Can just diff be replaced or does it need gearbox as well?
Have you checked the oil for correct level? If the diff's not dropped a tooth I'd start with an oil change to the correct 75W80 and (personal preference) add a tube of PTFE paste.
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
