  • 5 Vote(s) - 1.6 Average
Coolant Temp Sensor (peak and STOP)
Hi there
My temperature gauge going rocket high and the STOP sign coming on, and after hile and some few minutes of rest, everything is back to normal for a month or so.
Seems like there is no leak.
So now i am going to check all the sensors, But which one?
Anyone else experienced this?
I will add the parts from the catalogue here as a screenshot, sorry for the Swedish here:
but maybe someone will know witch essential parts i need to change here?
[Image: 2n69lxz.jpg]
CAR: berlingo 1.4i petrol, multispace, 2005 model
My Car INFO:
CITROËN BERLINGO (MF) 1.4 i (MFKFX, MFKFW)
2005 Mod
Volum: 1360 KW: 55 HK: 75 Fuel: Gasoline
Are you sure it is not the exhaust being blocked? A catalyst which is dying from old age, can produce those effects sometimes.
(18-10-2013, 11:34 AM)addo Wrote:  Are you sure it is not the exhaust being blocked? A catalyst which is dying from old age, can produce those effects sometimes.
Well, i am note sure. But i do not think it is that problem.
If so, what other signs should i look for then?
that i should feel on the power of the car right?
Fan runs after cars ignition are off for about 2 minutes, as it thinks the engine are hot (and it is not)
When i disconnected the thermo contact, it produces the same error with a ice cold car ( cleaned the connectors a little bit to see if that helps)
Have not driven the car hot today
My Car INFO:
2005 Mod
Well, today it happened again. So i will try to change the sensor.
Today i only disconnected battery, reconnected, and all fine again.
That shows me there is a sensor problem..or?
My Car INFO:
2005 Mod
Make did the same, random peak temperature, changed the sensor, problem solved.
I'd get a good look at your particular sensor so you know which you need as there are different ones.
(18-10-2013, 05:06 PM)steve valentine Wrote:  Make did the same, random peak temperature, changed the sensor, problem solved.
Steve, i will take out it tomorrow, and post a pic.
Seems quit easy to change. sits on top right, between the engine and airfilter.
My Car INFO:
2005 Mod
here is the sensor i suspect gives me the error. Sits on top of the engine, between the block and airfilter on a berlingo 1.4i
[Image: 30lyyhh.jpg]
I could not find this sensor on my list i posted earlier
My Car INFO:
2005 Mod
So after some tests, i changed the coolant liquid sensor as the post over, and have been driving for a few days with no errors.
Solved Smile
Prise 10 pounds
My Car INFO:
2005 Mod
[-] The following 2 users say Thank You to Varg for this post:
  • addo, Ol'Jeffers
Thanks for updating us with the outcome as it helps other people.
Glad you got a good result.
Yesterday 12:21 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
17-10-2026 05:41 PM
