  • 6 Vote(s) - 2.5 Average
front wheel bearing failure
Well folks..after fitting a new (Lucas) front bearing (& new hub for good measure) it would seem we're back to square one within a month!
Yes that new bearing, despite IMO going in well, & despite at the time of post-fitment the wheel spun lovely..it now has more play than the original knacked-one!..?? Do I need to be looking elsewhere for a cause here? (it's only done about 800 miles at 45/50mph)
..stub axle? severe bad alignment? Confusedcratch: :S
Any suggestions most welcome...Cheers now.
I've not had a problem with the Berlingo but my daughter's Corsa wore bearings out due to a damaged stub axle. What torque are you tightening the hub nut to ? I can't find a setting for it but it looks like a straight bearing and they are usually VFT. The rear ones are around 200 lb/ft but I can't find a reference for the front ones.
Yes ffrenchie..I'm wondering if the bearing or hub was not fully pressed 'home'..& what felt tight when I swung on that 3/4 drive T-bar was in fact not nipping everything up..??
Gonna blag that big socket etc off my farmer-mate this w/end & see if that nut will go some more..?
(I will be well happy if that's the only fault here).. Cheers now..U.S.
320 newton meters
235 ft/lbs then...
  • addo
Yesterday 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
