  • 3 Vote(s) - 2.33 Average
08 multispace adaptor 4 Audio
Evening all.
Im newish to the Forum and also to Berlingo Adventures.
I have this scart lead type plug here in my n/s/f glovebox.
I am told by my friend this is an adaptor for Audio Unit. and it will accept a bluetooth / ipod device.
My search thru this forum and google and ebay havent shone much light on :
What cable
What device
i should be searching for.
Humbly Yours
Jon
Are you talking about this one
[Image: 2nvthdy.jpg]
That is the diagnostic socket
YES..
That explains a text i received saying download Torque from play store from friend.
Aparrently you get to review engine output possible faults etc etc.
I have been led astray.. not for the 1st time in my life... not by a female at least....
Thank you.
On my 2010 110 XTR, I've got a separate Audio socket inside the glove compartment as per pictures below and I just needed to get a 3.5mm mini jack (headphone) to RCA Phono cable to connect my Samsung phone to it, but you can connect anything that uses the small headphone type socket.
One like this one
I did originally try a good quality thick cable but I couldn't close the glove compartment, so in the end I just used one with a thin cable which allowed the glove compartment to close (like the one in the link)
[Image: glove.jpg]
[Image: audio.jpg]
NTM...thank you for your posted reply.
i believe i dont have same adaptoras you.
Wifey has car at work right now..i will check it out when car returns.
Again thank you
jon
Yesterday 10:07 PM
Yesterday 10:01 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
