  • 3 Vote(s) - 2.33 Average
Lower Suspension arm -front
Hi,
Managed to bend the wishbone clipping a kerb earlier this week. Have tried to replace it today but it appears the p-shaped bush bracket is clamped in place by the anti roll bar. Do I have to remove the anti-roll bar too?
No, but you should have the entire front raised evenly in the air and both wheels removed. The opposing side clamp will retain the ARB's correct position.
(19-10-2013, 09:01 PM)addo Wrote:  No, but you should have the entire front raised evenly in the air and both wheels removed. The opposing side clamp will retain the ARB's correct position.
I think I might be missing something. The anti roll bar appears to be clamped into place with two plates bolted onto the subframe that share a stud with the p bush on each wishbone. But they are bolted on the top of the wishbone plate, so not sure how I remove the wishbone off the stud without removing the arb?
You should find it's a bolt, not a stud. I'll try to get a service diagram up in a bit.
EDIT:
  • ulysses
Rear light cluster removal
Last Post: phydaux
Yesterday 11:47 AM
Cranks but won't start
Last Post: MarkA67
Yesterday 10:45 AM
Last Post: BrianS
Yesterday 10:35 AM
ignition lock ggrrrrrrrrr
Last Post: Sikez2012
17-11-2025 10:07 PM
Engine Fan Running
17-11-2025 09:59 PM
Bettery Issues - A Solution.
17-11-2025 10:45 AM
Sound proofing windscreen
16-11-2025 02:43 PM
14-11-2025 07:34 AM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
