Threads: 3
Thanks Given: 1
is possible to remove the front strut, without using spring compressors.
i understand that you only need the spring compressors when changing the spring itself.
Threads: 67
Thanks Given: 1,045
Sure, you may need to remove the wishbone to free the ball joint taper but it can readily be done.
• billyf
Threads: 17
Thanks Received: 40 in 32 posts
Thanks Given: 6
After removing the ball joint nut/bolt knock a chisel in the gap to spread it open.
Griff
Landmark
Ex 1.4 Berlingo Multispace
