  • 4 Vote(s) - 3.25 Average
[Steering & Suspension] M49 Hubs on M59
Hey guys. Anyone know if the mk1 1.9d hubs will fit a mk2 2 hdi ? I have wheel bearings gone and want to keep the van going while i Work on the hubs. Even any other hubs ie 206, 306, Picasso that will fit. I'm in Northern Ireland and there is next to none m59's being broke.
Cheers in advance lads.
Don't quote me but as long as the Mk1 is 1999 or later it could fit.
There are slight differences in the part numbers like the 2.0hdi lower ball joint is 18mm dia. compared with 16mm on the earlier ones.
best to check side by side. Confusedalut:
Thanks for the reply rustscrat. I'll just see of I can one and test fit it and hope for the best. I read somewhere the m49 changed to a 18mm Ball joint so what your saying makes sense.
The other test is your disc specs - look at the Brembo aftermarket online catalogue. If the "hat" is taller on an HDi then the hub's internally splined section is longer.
Cheers for the info. I managed to get my hubs off and put two bearings in them in 5 hours and for £65 so didn't have to worry about buying another set.
Hi there, just wondering what method did you use to extract the old bearings and push the new in. Did you do it yourself with a vice etc or get someone with a press to do it? Did you have any problems removing the Drive Shaft nut? Just had one done at my local garage and they had fun undoing the nut. At one point they thought the Drive Shaft might snap off it was that tight. Finally after applying some heat it undid. Charged £110 including bearing. Took just under 4 hours. (One side).
Smile it's already happened! Big Grin
Last Post: TGD
Today 09:50 PM
Today 12:29 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
