Threads: 3
Thanks Received: 13 in 8 posts
Thanks Given: 3
24-10-2013, 10:45 AM
As part of fitting the OEM Citroen alarm kit. 9471 N5
It mentions using a Lexia to change the volumetric to increase it from 11 to 13
Is this needed ?
Does it just making the sensors more sensitive ?
Can anyone with a spare minute and a Lexia, please have a quick look under the Alarm section.
Can the Alarm kit be fitted and work from the original Key fob, without Lexia programming ?
Thanks in advance
Regards
Alan
Threads: 50
Thanks Given: 743
Now that's a question I would ask our new member dumdum! He's all clued up on alarms and stuff a la Lexia!
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
i was more the after market alarm sector, but i suspect your right that changing the sensors from 11 to 13 will just increase sensitivity
as for the alarm fitting, i suspect it will need configuring on the lexia in the bsi to enable it to work but it should work just fine after that from the original key fob
The following 1 user says Thank You to dumdum for this post:1 user says Thank You to dumdum for this post
• T1NY
Threads: 3
Thanks Given: 3
25-10-2013, 06:15 AM
(This post was last modified: 25-10-2013, 06:28 AM by T1NY.)
I'll let you know how I get on.
Alan
Just realised where I recognise dumdum from ;-) TA. :-)
