Threads: 6
Thanks Received: 4 in 2 posts
25-10-2013, 07:40 AM
(This post was last modified: 25-10-2013, 08:08 AM by delticol.)
My 2003 1.9d non turbo Berli van (is this the DW8?) has started to smoke badly and has no power. Its done 90k. I have recently changed the oil & filter. Put 5-30 fully synthetic long life oil in. It was running fine untill the other day when it struggled to pull up a hill, looking in the mirror it was pouring smoke from the exhaust. I got home and stripped and cleaned the EGR valve, intake etc. No change so replaced the fuel & air filters, no change. The smoke smells like parrafin, unburnt fuel I guess. Its now at a local garage where they think it could be the crank sensor. Anyone had a similar issue?? :brickwall:
Threads: 4
Thanks Received: 2 in 1 posts
I had the very same thing happen to me I thought that the engine had gone but then found out it was a blocked exhaust system replaced it from front to back and it run like new
Threads: 6
Looking like a collapsed cat....
Threads: 6
Sorted, new cat did the trick, goes like a good-un now, well with 71 horses anyway.....
