  • 3 Vote(s) - 3 Average
Fuel Filler Flap Puzzle
Hi
I am thinking about buying a used MK3 Berlingo. I was looking at one today and happened to pull open the fuel filler flap. When I pushed it to close, it was blocked by a little black rubber toggle to the left of the fuel cap. Eventually I figured out that if I press the toggle down, the flap could close.
I'm guessing that this is something to do with the system which prevents the door from opening when the fuel flap is open.
So is this broken, or do you normally have to push this toggle down when you close the flap ?
I've got a 2010 diesel and there is nothing to push to close the flap.
There is a built in mechanism that stops the sliding door from being opened if the filler flap is open. It is for safety, but it is automatic and has been on all multispaces from day one of the 5 door.
Peter
Is there a lever inside that you should have used which resets the toggle when the flap is opened properly ?
(26-10-2013, 08:12 AM)ffrenchie Wrote:  Is there a lever inside that you should have used which resets the toggle when the flap is opened properly ?
Does anyone know if there is a fuel flap release lever inside the car ?
There has not been one in either my M2 or Mk3, least not that I have found.
2011 B9 DPF warning light
Last Post: IKUN
Yesterday 09:44 PM
Frequent DPF REGEN's
Yesterday 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 02:29 PM
Last Post: paulod
Yesterday 12:05 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
Yesterday 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
Yesterday 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
Spot the Berlingo(s)
16-01-2025 12:20 AM
knocking from rear
15-01-2025 04:59 PM
Last Post: Andhall
15-01-2025 04:59 PM
