  • 6 Vote(s) - 4.5 Average
air bag removal
how do you remove the steering wheel air bag on a mk2?
usually its a torx of some size is it the same for a mk2 'lingo?
MK1 Berlingo, Y-Reg 1.4 Petrol Now LPG Converted.
There's a tutorial on it somewhere here. Try a search for Com2000 change or Horn button earth etc.
Here you go. Confusedalut:
.pdf   Mk2 airbag removal.pdf (Size: 25.02 KB / Downloads: 54)
[-] The following 2 users say Thank You to Rustscrat for this post:
  • cbeck113, john
space is quite limited behind the wheel, not quite sure how you'd get 3 screwdrivers behind it Confused
Do one hole at a time and turn the wheel to get access. If I can remember you just push up on the wire inside to release each clip.:thumbsup:
Last Post: TGD
Today 09:50 PM
Today 12:29 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
