  • 4 Vote(s) - 2 Average
Abs light not clearing.
Hello again folks, its been a while since I've had any faults with my berlingo. This one is my abs light. I had it plugged into the diagnostics which showed a rear left sensor, I have changed this, driven up and down the street and light is still on.
I have checked all fuses etc and all seem to be intact. It's mot time next weeks so now getting a little worried.
Am I missing some step in the process or is there another way to reset the abs system.
Thanks in advance for any help...!
Cheers... Dave
I think I'd re-run diagnostics and clear all old faults then see if anything fresh surfaces.
The sensor fault may not be the sensor. It might be the wiring leading to it or dodgy multi-plug connection.
  • drussell7299
Thanks... That's my plan on Tuesday, then ill proceed with further investigation.
Thanks... Dave
After more diagnostics, still showed rear left fault... Eventually found that it was a coroded wire on the section before the sensor. This was then stripped and repaired for free by the garage who carried out the diagnosis.
Problem solved just before mot..... Phew.
Dave.
[-] The following 1 user says Thank You to drussell7299 for this post:
  • addo
sliding door panel removal
Last Post: mojito
Yesterday 07:35 PM
XL tyres
Yesterday 06:57 PM
Last Post: deejay_xb
Yesterday 10:06 AM
» Replies: 32
Unusual Braking Problem
Yesterday 07:57 AM
Outer cv boot replacement
22-03-2025 10:13 PM
22-03-2025 10:02 PM
Diagnostic Plug
22-03-2025 09:55 PM
22-03-2025 09:52 PM
Rumbling Noise 55-65mph
22-03-2025 09:47 PM
Last Post: Beaumotor
21-03-2025 04:38 PM
