  • 4 Vote(s) - 3.25 Average
What is it?
Hello all.
So, having purchased a 2.0 Berlingo (54) earlier this year, I decided to do some easy repairs myself. I've followed some advice on this site and thought I'd join as a) I need more help and b) hopefully I'd be able to help someone else one day.
Now, I'm no mechanic and as the Haynes manual would grade me: I'm a level 2 spanner. But, I've just managed to avoid giving Halfords £120 for replacing the anti-roll bar droplinks. Last week I changed my washer bottle pump. See, level 2 spanner I tell you.
Now, question: what is the part called in the picture.? It was broken off near the nearside brake disc.
Many thanks
Pricey
[Image: ndasfk.jpg]
Welcome to the forum
It will help if a little more info if possible is given .
What material is IT made of ? Rubber, plastic or metal or whatever and approx. what size is IT ?
Has IT or the lack of IT affected your brakes?
With the Berlingo that you have you will find they are relatively easy to maintain yourself and you soon learn its quirks. You'll be a master Berlingoman (3hammers) in no time.
:thumbsup:
ABS sensor?
(28-10-2013, 07:32 PM)Modmytop Wrote:  ABS sensor?
I think it maybe a heatproof cover for the abs sensor. But can't seem to find such part.
Looks like the "ABS Speed Sensor cover".
Part No. 4547 79 :thumbsup:
[Image: 1zeumav.png]
[-] The following 3 users say Thank You to Rustscrat for this post:
  • Pricey, RolyG, ron
(28-10-2013, 09:25 AM)brodfather11 Wrote:  Welcome to the forum
:thumbsup:
Hi brodfather
Thanks for the welcome. The material is phenolic heatproof. It is around an 2 inch long an inch wide and an inch tall. It is screwed on but has broken away from the screw. It is an heat shield cover of some sort. Think it might be covering the Abs sensor if that is what it is.
Thanks: I've still got a lot to learn before my grade 3 spannerConfusedtudy:
(28-10-2013, 08:21 PM)Rustscrat Wrote:  Looks like the "ABS Speed Sensor cover".
Thank you so much. That's the one. You just posted the answer as I was just posting my other replies. :thumbsup:
[-] The following 3 users say Thank You to Pricey for this post:
  • Ol'Jeffers, ron, Rustscrat
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
