Thanks Received: 2 in 2 posts
27-10-2013, 09:08 PM
(This post was last modified: 28-10-2013, 08:11 AM by carwood.)
Hi there new to the forum first post hope someone can help. I have a 2006 1.9d berlingo revs ok when stationary go to drive its slow but picks up at 2750 rpm changed the EGR valve still no good the clutch isn't good thaught some Debre had damaged the fly wheel sensor fitted new one still no good any ideas no light coming on no fault codes showing. also when van gets up to temperature after going down gears when go to take off you get a diesel knock switch van off and on and knock dissapears
The following 1 user says Thank You to carwood for this post:1 user says Thank You to carwood for this post
• Ol'Jeffers
Threads: 43
Thanks Received: 411 in 368 posts
Thanks Given: 137
32
Sounds to me as if the engine injection timing is out .
Camshaft belt slack or pulley loose, camshaft sensor faulty (if fitted).
Remove the cam cover and check the belt
do you need pins on dw8 to check timing
Threads: 43
Thanks Given: 137
32
yes you need pins to set and check camshaft timing , or drill bits the right size .
I think its either 8mm or/and 6mm dia.
Has there been any work done to it before the problems started ?
no. Theres a solinoid with two breather pipes conecting to the egr valve will change that after i check timing
Hi there sorry it took so long timing ok the solinoid is working fine took the cat off van is running fine
• addo
Back again van running like s**t it seems to be over fueling lots if suit out the back of the exhaust when you go down the gears and go to take off again diesel knock switch off and on van goes ok anyone any ideas what it could be
Threads: 43
Thanks Given: 137
32
The advance solenoid on the fuel pump sticking ? ( this depends what engine you have) or wires to it having a bad connection
Threads: 5
Thanks Received: 1 in 1 posts
Thanks Given: 15
Hi did you think of checking the 'butterfly' before the inlet manifold? There are 2 vacuum pipes connected to it, seen them giving bother before.
