  • 4 Vote(s) - 2.75 Average
Alternator change on 2.0 hdi
I need to replace the alternator on an 06 2.0 hdi can any one help me with this as i have taken the 2 bolts from the bottom one which holds the tension pulley and 1 from the top, is there another 1 at the top because if there is then the power steering pump would seem to obscure it..
Cheers
Ian
there are four bolts in total in a mirror image of each other, so the top two are the same positions as the bottom two roughly speaking
Thanks for the reply..
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
17-10-2026 05:41 PM
