Threads: 50
Thanks Given: 743
Depends what work they're going to carry out on it once it's removed....
Threads: 67
Thanks Given: 1,045
So, head R&R, head service/check, new valves, aux belts, timing kit, water pump, PAS flush, brake fluid flush and bleed (why not; you're in there). If you had a belt failure it may also be that you need rocker arms.
Threads: 67
Thanks Given: 1,045
That's a question perhaps better answered by Lighty. I've never done an HDi head - Diesels aren't that common here yet. I'd be surprised if a competent workshop couldn't have the head sat in the parts washer within ninety minutes. Cleaning and reassembly - not including consumables or sublet works, at a complete guess two to three times the dismantling hours until it's ready to drive away.
