  • 3 Vote(s) - 2.67 Average
Removing Bluetooth Gizmo
Hi
Just bought a used Mk3 Berlingo. The previous owner installed a gizmo which I have indentified as a Parrot bluetooth device.
As you can see in the photo, a wire to the device emerges from below the panel above the radio.
I have no use for this thing and want to remove it. How do I open the panel above the radio to disconnect it ?
Thanks.
Photo??
Sorry the photo did not seem to appear in previous message
[Image: 2jctxqd.jpg]
If you're removing the whole lot, is it for sale?
I would start by removing the radio; you can see the release tool holes on the right in your picture. That should help you see how to remove the upper cover.
(31-10-2013, 07:42 PM)addo Wrote:  If you're removing the whole lot, is it for sale?
Yes. Good point. That's probably how the wire was put in. Where can I get the release tools or something else to do the job ?
You can get the correct tool to get the radio out from a motor factors or halfords or you can use correct sized nails or a bit of strong bent wire. They look like this http://www.ebay.co.uk/itm/UNIVERSAL-RADI...35cca2aaa4
Yes, they are the dedicated type I recommend for the novice. Nails, wire etc work OK if you already know what you're "feeling for" with the little spring catches.
I use 4 x 3mm hss drill bits
Thanks to all who helped. I think I will be able to sort this now.
I removed the radio and found that the wire from the Parrot bluetooth device leads somewhere round the back of the centre display (Time/Date etc)
Why does it connect there ?
Also - I would be happy to just cut the wire and chuck this thing away, rather than remove the display unit to unplug. Any risk of a problem from doing that ?
UPDATE : For the time being I have bundled the device and its wire with cable tie and shoved it all in behind the radio. So if I change my mind, I can always bring it out again.
Today 04:31 PM
Today 11:13 AM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
