Threads: 18
Thanks Given: 4
Just lifted floor mats of my Mk3 and noticed that there are 2 holes in the floor of the drivers footwell. One has a plug in it and the other is missing the plug.
Anyone know where to get one of these plugs other than a dealer ?
Threads: 18
Thanks Given: 4
Thanks Ol'Jeffers. Bog standard grommets would probably do the job.
Having looked at some floor mats which are available to buy I see that there are 2 equivalent holes in the driver's floor mat. So I think that these "plugs" are actually designed to hold the driver's floor mat in place.
Threads: 50
Thanks Given: 743
Personally I wouldn't rely on the presence of floor mats to keep the floor watertight.
I'm assuming that when you look through the holes you can see the road beneath.
I would fit blind grommets and put the mats over the top. It sounds like one of Citroen's
typical ill-thought out ways to save on-costs.
Threads: 18
Thanks Given: 4
No can't see the road underneath. Grommets should do the job.
Thanks a million.
Threads: 6
Thanks Received: 7 in 4 posts
Thanks Given: 4
01-11-2013, 03:25 PM
(This post was last modified: 01-11-2013, 03:48 PM by m mouse.)
i have a mk2, it has two little up stands in that location that plg into the rubber mats to keep them in place, only on the drivers side as i remember,
i think they have a very coarse thread on the underside that screw into the carpet
mickey
Threads: 16
Thanks Given: 46
5
If you mean you have lifted the actual carpet & the hole is in the metal floor then Halfords do bags of assorted gromits. If you mean holes in the existing carpets then the holes don't go through the floor just through the carpet. If you buy a new set of floor mats they should include a pair of these plastic bits that screw into carpet to stop driver's mat moving.
