  • 15 Vote(s) - 2.47 Average
Problem with 2007 1.6 hdi
Hi all got a Citroen berlingo in 1.6 hdi 2007 model it started but ran like a bag of hammers really loud diesel knock and wouldn't rev over 2k and was giving really black smoke out the exhaust
The next day it wouldn't start
I have checked the timing and put a new belt kit on
I've put new injector seals in and recoded the injectors
It won't run off easy start aswell turning the crank by hand it feels like it's got plenty of compression
I've cleaned out the erg valve
And snap on machine is only bringing up the code 1351 glow plugs
When I test erg on machine it works but when I test diesel pump pressure and fuel rail pressure it carnt test cause if a module
The e.c.u is unlocked and working with the bsi
Blocked cat/exhaust?
It could be will check Monday when back at work but it was smoking pritty bad so didn't think it would be blocked
Backpressure from blocked exhaust = no air sucked in + fuel injecting merrily away = unburnt fuel =black stuff.Confusedalut:
It's not the exhaust checked
Not the rockers
Had a new crank sensor
New cam sensor
New timing belt kit timing checked over
New injector seals and tested
Live data on fuel pump and that makes its pressure
New diesel filter
New air filter
Cleaned and tested the erg valve
Cleaned and tested the throttle bodie and surrounding sensors
Turbo is fine
Bottom end is good
But it still won't start the pick up on the crank pully for the crank sensor is suspect there isn't nothing that would give off a pulse for tdc
Does anyone have a pic
Leaking windscreen or aerial
15-04-2026 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
