Threads: 11
Thanks Received: 4 in 1 posts
Thanks Given: 7
i put comma fully sythetic 5w 40 see some people using 5 30 is there any difference
Threads: 50
Thanks Received: 475 in 420 posts
Thanks Given: 743
04-11-2013, 01:00 AM
(This post was last modified: 04-11-2013, 01:04 AM by Ol'Jeffers.)
The difference could well be the price of a dpf or worse, a turbocharger.
QUARTZ INEO ECS is the only low SAPS oil recommended by PEUGEOT and CITROEN.
NORM PSA PEUGEOT & CITROEN B71 2290.
However any brand of oil that is said to adhere to the above spec. will be fine.
Comma recommend Syner-D 5W-40 which, strictly speaking does not meet the correct specification.
They don't appear to market an oil which does.
The one thing about the 1.6HDi that needs to be taken very seriously is the engine oil used.
Personally I would drain the oil and put in the right grade. Neilsen CDG will deliver the right stuff to your door probably cheaper than the price you paid for the Comma.
Threads: 29
Thanks Received: 375 in 329 posts
Thanks Given: 67
20
(03-11-2013, 11:24 PM)bigbubba85 Wrote: i put comma fully sythetic 5w 40 see some people using 5 30 is there any difference
10 difference
The following 1 user says Thank You to ffrenchie for this post:1 user says Thank You to ffrenchie for this post
• addo
Threads: 67
Thanks Given: 1,045
Bang on!
But to be serious, I think OJ is the most qualified to talk oil here.
• Ol'Jeffers
